surging at idle at loss. any ideas?
Old Feb 12, 2007 | 09:14 AM
93yellowta's Avatar
Well for the last month or so I have been getting a 100-150 rpm surge about every 3-5 seconds at idle in park. wether the car is cold or warmed up. My opti is about 1 yr. old, plugs/wires/lifters/pcv about a week old. 02's about 7 months old. and seem to be switching fine on my scanner. going into closed loop also. car seems to be running strong. not breaking up. showing alittle rich at idle on my scanner, but I believe it is overlap from the cc306 cam. actually when I pulled all 8 plugs to put in the new ones, they were more white than beige. almost like a lean condition. I do have the lower rpm surge when cruising from the cam. but car does not break up runs strong thru the rpm ranges.. no codes. so at a loss any ideas? oh yeah walbro 255 fp. kirbin afpr. and autometer electric fp gauge.does not seem to be dipping or dropping when car is surging. also fuel filter is about 8 months old... just at a loss?
Old Feb 12, 2007 | 04:40 PM
93yellowta's Avatar
ttt...
ttt...anyone?
could it be the IAC? It is original.
Old Feb 12, 2007 | 04:42 PM
SStrokerAce's Avatar
Could be it's sticking.
Old Feb 12, 2007 | 05:27 PM
93yellowta's Avatar
Iac..
Thanks Bret I' replace it, and see how that helps.
Old Feb 12, 2007 | 05:59 PM
You could need a new IAC or just clean that one. Don't know but that COULD be the problem.
Old Feb 12, 2007 | 06:29 PM
93yellowta's Avatar
I did clean it about 6 months. ago. I'll try that again first... thanks..
Old Feb 13, 2007 | 05:00 AM
Guest47904's Avatar
Guest
Scan it
Put it on a scanner and see what the IAC counts are doing. As well as some other read outs. Wouldn't hurt to check actual engine vacuum levels as well.
Old Feb 13, 2007 | 07:33 AM
93yellowta's Avatar
well Im pulling around 10-11" of vacuum at idle, I heard about normal for the cam Im running. no vacuum leaks, I just replaced the lifters. and the intake is sealed up tighter than a drum. and all new vacuum lines.
on my scanner Iac counts is about 47-50 counts. fluctuating at idle. when cruising down the highway around 2700 rpms counts are around 116...
Noenav
Apr 30, 2015 01:06 PM
reww86
Apr 27, 2015 05:17 PM
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
