Surging...black smoke
Old May 1, 2006 | 08:46 PM
Matts1994Z28's Avatar
So after the last few days of driving i have noticed my car will surge when im at idle...it surges about 200rpms and sounds like i have a nasty cam in the car. it also smokes a tiny bit when this is happening. but it doesnt always surge and it seems like it only does it after i have been driving a bit. I have ran leaded race gas a few times but not to much...maybe 6 gals at the most over the last 2 months...always mixed with a full tank of premium. so im thinking maybe the lead got to the o2's?? the motor its self has about 34k on it and the body has 104k...im not sure if the o2's have ever been replaced. is there anything else is can be? im not throwing any ses lights. back in december i had the car dynoed at it was running a bit lean...now it seems like its going rich when this happens....any ideas???
Old May 2, 2006 | 07:50 AM
Re: Surging...black smoke
anyone?!
Old May 2, 2006 | 05:22 PM
ttt
Old May 2, 2006 | 06:02 PM
Honda Hunter's Avatar
I'm 93.7% it's the o2's. Mine did the same after using tons of Torco race fuel addative. Ended up being the o2 sensors and I never got a solid code indicating it. The scanmaster saved the day by showing me my o2 readings. I think Injuneer once told me it only takes one time using lead to kill the o2 though they are rated for a couple of hours of use or so. Hook up freescan and go from there.
Old May 2, 2006 | 07:58 PM
well i decided to pull the o2's and one was bright white...only on the passanger side though...what could cause that? bad plugs? im not sure when the plugs were last changed...
Old May 2, 2006 | 07:59 PM
I wish you could hook something up to monitor the o2's. I'd change both o2's and the plugs.
Old May 3, 2006 | 07:27 AM
yeah thats what i was thinking...im going to try and do the plugs and wire this weekend. i do have access to freescan now so i might scan it and see whats going on. thanks for all the help, i appreciate it.
Old May 3, 2006 | 07:30 AM
No prob. good luck.
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
alphaauto
Jul 26, 2015 04:40 PM
