Broken Valve Spring
Old May 2, 2006 | 09:20 PM
4DRSS's Avatar
Angry Broken Valve Spring
Pulled my valve covers today because I developed a miss and suspected a valve train problem.
Sure enough I have a broken valve spring. Good news is it appears it's a clean break (no pieces), the rocker is OK, the pushrod looks good, and the valve didn't fall in the cylinder.
Now the dilemma is do I just replace the spring or should I pull the head? I really don't want to pull the heads unless I absolutely have to. Any suggestions?
Here are a couple pics
http://www.regionofdoomforum.com/Upl...SS/spring1.jpg
http://www.regionofdoomforum.com/Upl...SS/spring2.jpg
Old May 2, 2006 | 09:26 PM
Stoopalini's Avatar
Re: Broken Valve Spring
Do you know why it broke? What valvetrain setup and cam are you running?
Thomas.
Old May 2, 2006 | 09:31 PM
4DRSS's Avatar
Thomas.
Why it broke? Six years of shifting at 7,000 RPM I suppose They were setup by ARE back in the day, good for .600" lift, comp cams 306 cam, and AFR hydra rev.
I don't suspect it is a setup issue, I got my moneys worth out of them.
Old May 2, 2006 | 10:16 PM
luckyou03's Avatar
lucky you didn't drop the valve....
Old May 3, 2006 | 01:32 AM
MachinistOne's Avatar
What brand of springs are they, just out of curiosity.
Old May 3, 2006 | 06:34 AM
Shon Herron's Avatar
I would just replace all springs at this point. Dont have to pull the heads for that unless you want them 'reviewed'.
Old May 3, 2006 | 08:10 AM
Dave '97 Z28 M6's Avatar
I agree. If one spring broke, the others may not be far off. Might be time to go with the Comp beehives that are popular these days.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
