Supporting components for LE2 setup, missing anything?
Old Jan 24, 2006 | 11:45 PM
Javier97Z28's Avatar
Moderator
Ordering the LE2 setup within a few weeks, am I missing anything from the list below?...
Here's what I have so far (mostly from summit):
Comp Cams 1.6 Full Roller NSA 7/16" RR CCA-1305-16 $259.88
Comp Cams Magnum Chromemoly Pushrods CCA-7608-16 $109.39
Comp Cams OEM Style Lifter CCA-850-16 $239.95
Comp Cams 7/16" Rocker Arm Stud CCA-4503-16 $49.39
GMPP Guidplates 5/16" Qty: 8 NAL-14011051 (8 x $3.88) $31.04
Ford SVO M9593B302 - FMS-M-9593-B302 Injectors 30lb $204.88
How necessary is a 58mm TB at this point? I know Lloyd recommends it on the site, but I've read countless times the 48 is enough? And if so, does anyone open up our stockers to 58mm and throw new blades on 'em?
Old Jan 25, 2006 | 12:02 AM
Cmr0z28's Avatar
Re: Supporting components for LE2 setup, missing anything?
I believe 54mm is MAX for our throttle bodies, but that's pushing it. Most common is 52 for the stocker. If you go 58, the intake has to be bored out but that's easy.
Old Jan 25, 2006 | 12:30 AM
94Z396_0621's Avatar
Do you think a 58mm throttle body is necessary on a 396? I am using Bare Casting Trick Flow Heads worked by Loyd Elliott, 2.08, 1.625 valves with LT4 intake port matched to the heads.
Old Jan 25, 2006 | 01:03 AM
Cmr0z28's Avatar
Sure.
Old Jan 25, 2006 | 02:59 AM
sbs's Avatar
sbs
Make sure you shop around. Most of the prices you have posted are not competitive.
Old Jan 25, 2006 | 07:06 AM
Moderator
Yah, I heard that.. it's tough b/c alot of places are higher on some but lower on others. I don't want stuff shipped from 6 different locations either...
For example, summit is $100 cheaper on the injectors and $50 cheaper on rockers than thunder or speedinc.. while thunder is like $20 cheaper and smaller things like pushrods.
Any thoughts on where else to look?
Old Jan 25, 2006 | 07:51 AM
stroked383z28's Avatar
Combination has a sale going on through the end of the month. Check out the group purchase section.
Old Jan 25, 2006 | 07:56 AM
Moderator
Those kits include too much of the stuff that already comes with the LE stuff, not to mention the wrong rockers. Thanks though!
Old Jan 25, 2006 | 07:18 PM
2000GTP's Avatar
Javier, did you find those injectors at Summit? I'm planning on doing a similar setup with the same injectors this spring.
Old Jan 25, 2006 | 07:23 PM
Cmr0z28's Avatar
http://store.summitracing.com/partde...2&autoview=sku
Old Jan 25, 2006 | 07:26 PM
2000GTP's Avatar
Great, thanks for the link, I appreciate it.
Old Jan 25, 2006 | 07:51 PM
Cmr0z28's Avatar
no prob
Old Jan 25, 2006 | 08:47 PM
Moderator
Yah what he said.. glad he could help lol
Old Feb 12, 2006 | 12:31 AM
Bersaglieri's Avatar
What flywheel HP are you using to determine the injector size for this application?
-Dustin-
Z28Freak86
Apr 30, 2024 05:37 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Nutty's96
Parts Wanted
May 12, 2015 09:37 PM
NewsBot
Mar 30, 2015 12:40 PM
