Summitt Opti Spark
Old Mar 22, 2010 | 09:22 AM
hobrien's Avatar
Summitt Opti Spark
Has anyone used a Summitt Racing optispark, and if so how has it worked out?
Old Mar 22, 2010 | 05:41 PM
Steve0's Avatar
I believe that the summit unit is the same as the Accel unit which came out a few years back. If the description of it talks about a bushing instead of ball bearing, than they probably are infact the same unit.
https://www.camaroz28.com/forums/sho...highlight=opti
That was my story.
Old Mar 22, 2010 | 10:49 PM
mzgp5x's Avatar
I used one on a 97ss MM6 383ci D1 app. Failed in one year. The encoder would not work when the engine came to op temp. Engine would stop on the road multiple times. Lifted the hood and applied force to the connector, and, engine would restart.
I think the encoder had a bad solder joint @ the PCM power input pin. I went to a different opti. The high voltage and rear bearing were OK. Summit would not take a return due to it being 2 months older than 1 year from purchase. The encoder 4 pin connector will not fit good on these opti's. I fixed by removal of some of the plastic near the connector retaining clip for full pin engagement and secure detent. Hope this helps. B.
Old Mar 23, 2010 | 11:29 AM
hobrien's Avatar
This is good information, and I appreciate it.
Old Mar 23, 2010 | 11:31 AM
hobrien's Avatar
I am not sure what their literature says about bushings or ball bearings, but you are probably right. Thanks for the information.
Old Mar 23, 2010 | 01:21 PM
wrd1972's Avatar
Summit or Accel optis. Avoid like AIDS.
I had a Accel that had sparks shooting out the cap, the encoder wheel windows screwed up and the encoder wheel rubbing the optical sensor. Total ****.
Only get a GM opti.
Old Mar 29, 2010 | 10:40 AM
hobrien's Avatar
I appreciate your input.
Old Mar 29, 2010 | 01:37 PM
Read post #5 in this thread.
https://www.camaroz28.com/forums/sho...d.php?t=740761
Old Mar 29, 2010 | 03:07 PM
gelbza's Avatar
Put a Summit opti on a year ago, failed out of the box and may have possibly been linked to frying my ECM...not definitive, just a warning
jmadoll
Jun 10, 2015 04:41 PM
beltrunner
May 17, 2015 10:18 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
DTK
Aug 14, 2002 06:14 AM
