Suggestions for Stock computer CAM choice
Old Feb 17, 2008 | 09:19 AM
cougarL92's Avatar
Heres the skinny.. The is for my daily beater A 95' Z28 that's getting the motor freshend up and im thinking about adding a cam.. It has a 2400 stall, The heads will be ported, long tube headers, no cat, and a moroso Air induction.. But the thing is I really dont have the money at the time to spend $400-500 on tuning the PCM.. So what the best choice for a cam with still getting my moneys worth out of buying one?? Any suggestions would be great,, Thanks
Old Feb 17, 2008 | 09:58 AM
Have you looked at the mail-order tuning from people like pcmforless, trifecta, or MadZ28? They don't cost $500. More like $125-175.
http://www.madtuner.com/index.php?pa...id=26&vmcchk=1
http://www.pcmforless.com/index.php?...d=44&Itemid=40
http://www.trifectaperformance.com/
Spending a lot of money on parts, and then not having the PCM tuned for them is a waste of money.
Old Feb 17, 2008 | 10:00 AM
kylersaulsbury's Avatar
not to be a dick, but the only cam that works well with the stock tune is the stock cam. you don't have to spend 400+ on a tune. there are people out there ie: pcm4less and madz28 (now known as madtuner) they are very accurate and charge around 150 for a tune.
Old Feb 17, 2008 | 10:11 AM
96capricemgr's Avatar
Computer tuning is a good mod on a stock engine. In no way should you consider a modded engine on stock tuning.
For $500 you could buy a used laptop and all the software and hardware to be able to tune it yourself.
Old Feb 17, 2008 | 01:19 PM
2000GTP's Avatar
If you plan on porting heads and adding a bigger cam, it should not be done without tuning in mind. If a tune is going to push your budget, then a cam may not be the best idea right now considering there are "supporting" mods that should be bought as well which will drastically increase the overall cost of the project.
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
95chwagon
Jan 13, 2015 09:19 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
