sudden bad vibration. Help??
Old Apr 8, 2005 | 06:26 PM
KeVMaN's Avatar
Ok, my car has been running very smoothly and quietly lately, but today, i pulled in to a food place, and when i started the car again it was shaking pretty violently, and its quite a bit worse when its in gear that when it's in neutral. In the higher rpm range (like over 2000) it runs pretty much like normal although it sounds a bit different. What's going on here? Is it possible that i had a worn out motor mount and it finally broke? If i watch the motor when its idling it vibrates back and fourth very quickly. Should i order some energy suspension bushings (the car has 192K on it so it wouldn't surprise if if they were shot) or does there have to be something else wrong with the motor to make it shake that bad? Thanks.
Old Apr 8, 2005 | 06:38 PM
5.7LT1Formula's Avatar
Re: sudden bad vibration. Help??
i would check your wires and plugs. i bet one of those is bad.. had the same thing in my explorer..
Old Apr 9, 2005 | 10:59 AM
KeVMaN's Avatar
thanks for the suggestion i ll look into that. anyone else have any ideas?
Old Apr 9, 2005 | 05:08 PM
KeVMaN's Avatar
edit: It was a plug wire that was cracked right next to the top. Thaks for the help!
colts0455
Jul 8, 2015 12:21 AM
surreybrad
Jul 5, 2015 10:36 PM
jwade88
Jun 14, 2015 09:38 PM
markzzzz
May 8, 2015 09:21 AM
Ricardo
Nov 29, 2014 10:58 AM
