stupid question
Old Apr 6, 2007 | 07:16 PM
94blk-lt1's Avatar
stupid question
this might be dumb but i would like to know anyways. would i be able to start my engine with out the transmisson on connected to the fly wheel? i just want to know cuz i need a torque converter and i just want to hear my new engine rumble!!
Old Apr 6, 2007 | 07:41 PM
CrazyLT1's Avatar
Ya I would think you can. I have never seen it done - but don't see how it would hurt anything.
Old Apr 6, 2007 | 07:57 PM
LTgun_94's Avatar
How are you going to go about this? You need the starter to be connected to the flywheel for the engine to be turned. I mean somebody correct me if im wrong!
Old Apr 6, 2007 | 08:02 PM
aboatguy's Avatar
I've seen engines run without trannys; however, they've been on test stands.
Old Apr 6, 2007 | 08:10 PM
CrazyLT1's Avatar
I think he means that the flywheel will be on - but the tranny just won't be connected to it. I don't see why this would be a problem....
Old Apr 6, 2007 | 08:11 PM
LTgun_94's Avatar
But still he needs some sort of starter-type mechanism to start the car, right?
Old Apr 6, 2007 | 08:15 PM
CrazyLT1's Avatar
Why not just use the starter...??
The transmission being off has no effect on the starter working or not
Old Apr 6, 2007 | 08:22 PM
LTgun_94's Avatar
Doesnt the transmission provide support for the starter?
Old Apr 6, 2007 | 08:25 PM
CrazyLT1's Avatar
Nope - not at all. The nose of the starter just goes into a hole cut out in the bell-housing. But the transmission doesnt support it at all
The 2 bolts holding the starter up are bolted directly into the engine block
Old Apr 6, 2007 | 08:36 PM
LTgun_94's Avatar
Alright...that is what was getting me!
Old Apr 6, 2007 | 08:53 PM
seawolf06's Avatar
yes, it will work. That's how they put engines on an engine dyno!
Old Apr 6, 2007 | 08:57 PM
danhr's Avatar
impact and fuel iv..... seen it done a lot of times at junk yards....
Old Apr 6, 2007 | 09:20 PM
MyWifesZ28's Avatar
Sounds right to me, I always though as long as the crank is balanced by both damper and flywheel, all is well
Old Apr 6, 2007 | 09:22 PM
bingo's Avatar
I cranked my last LT1 this way. It revs very quick.
Old Apr 6, 2007 | 11:45 PM
94blk-lt1's Avatar
ok kool. so i can do it? is there anything i should watch out for? the engine does move alot when the tranny isnt connected to it.
