stupid knock sensor
Old Apr 15, 2005 | 06:03 PM
EVERESTZ28's Avatar
stupid knock sensor
be careful if you want to remove the knock sensor, i needed 3 days it's like [EDIT] welded on block, and the little space you have to make your moves!!!!! i needed to remove the starter ....... don't try to remove unless you are 100% sure you need it. just a warning.
Old Apr 15, 2005 | 10:25 PM
OBE1 95Z28's Avatar
Re: stupid knock sensor
The threads on the sensor have loctite on them. Applying localized heat on the block with cause the loctite to "loosen". Just don't overdue the heat as you might damage the sensor.
SergheiS
Jul 5, 2015 03:27 AM
99z28 carguy
May 26, 2015 11:35 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
