dude [xxx]?? AC Delco oil filter
part # PF454
I'm losing all my oil threw this oil filter...WTF IS GOING ON??...Ive never had this problem before with an oil change or with any other filter, I lubed the ring before putting it on, and I hand tightened it...My oil is still pouring out of this [EDIT]...Ive tried adjusting it multiple times, tighter or looser it is still coming out!!
soemone help!!! Mobil 1 isnt cheap!
Moderator note: Do not "test" the language filter.
Re: dude WTF?? AC Delco oil filter
Are you certain that you didn't leave a gasket from the old filter on? Probably not, but I remember doing that once. The new filter wouldn't seal with the old gasket on it. Just a thought.
Could be a bad filter. Just take it back and replace it. I've used 20 or 30 of those 454s and they're great. I use the 1218 (the longer one, i think thats the #) now.
I'm guessing it is an old gasket still being on.
I've never had any problems with Delco filters and there isn't really another way for the filter to be leaking unless it had a hole in it.
On my 97 the oil pressure sending unit is right at the back of the intake manifold, Im guessing its the same on 94's but there is a pipe plug right above the oil filter adapter ( for a manual oil pressure gauge) but how could that plug could have backed out all of a sudden???
CHECK THE FACTORY OIL cooler. its inbetween the oil filter and the block. bolts may be loose. mine 94 formula leaked back there after an oil change. then i tightened the oil cooler and the leak was gone.
Originally Posted by Formula_driva
Is the oil pressure sensor just above the oil filter???
CUZ YEAH.... ITs SNAPPED OFF
Originally Posted by shoebox
1993s and early 1994s have the oil pressure sensor above the oil filter.
Jul 4, 2005 05:00 PM
