Stupid a/c question
Old Jan 8, 2004 | 03:37 PM
1fast95Z's Avatar
Question Stupid a/c question
OK, this may be a stupid question but I've never had to change the a/c compressor in this car before. I got the old compressor out with little problem but the shop manual states that I need to add 8 oz of synthetic oil to the replacement compressor before installing it. I looked on the back of the old compressor and all I see are the ports (suction and pressure I assume) and another port directly in the middle that has a threaded plug in it. I took the plug out, thinking this was it, turned the compressor upside down expecting oil to come out of it, but nothing came out. Now, where in the hell do I add this oil?
Old Jan 8, 2004 | 05:45 PM
BlackDog's Avatar
It doesn't matter which hole you put in. Hold the compressor with the holes straight up and the pulley side down. Pour in the fluid, then start turning the pulley with your hands 5-6 full turns to circulate the fluid. Then reinstall the compressor.
jasonduaine
Mar 7, 2015 09:44 AM
grgguy
17
Feb 23, 2015 07:57 PM
alphaauto
Feb 5, 2015 05:25 PM
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 15, 2014 03:09 PM
