LT1 block and Heads
Old Jan 7, 2004 | 11:59 AM
GrnHornet's Avatar
LT1 block and Heads
I have an 95 LT1 block w/heads. It's been bored to .30 over stock, but not honed. I don't want a stroker. So could I just get larger pistons to match the bore to rebuild the bottom end? Also I'm looking for 400-425 rwhp. Is this possible by doing a head/cam package? One last thing this will be my daily driver. Any thoughts appreciated thanks.
Old Jan 7, 2004 | 01:12 PM
zjet's Avatar
1st it need finished honed have it honed to fit the new pistons
2nd head/cam package will easily make 350-400 rwhp and be very streetable.
there no need to stroke it if you dont want us the stock crank and rods get some arp rod bolts though
Old Jan 7, 2004 | 01:40 PM
CamaroBoy96Z28's Avatar
.030 overbore with the stock crank and matching internals for the setup puts you at about 355ci. Dont worry about driving on a head and cammed car every day. I drove my friend's 93 Mustang GT with AFR 165s and custom cam running 12.14@111mph around and it was perfectly fine with the T-5 and 4.10s. His friend from school drives a 2000 SS making 454 rwhp on a 414ci stroker that he drives everyday including now.
Making 400rwhp should be very much conceivable. Its getting more and more common, plus it helps having a fresh bottom end. All you need is the right combo and theres plenty of sponsors on the board who can help you out.
Old Jan 7, 2004 | 08:49 PM
GrnHornet's Avatar
Hey sorry for the late reply but thanks. Does anyone have any suggestions as far as What type of pistons, i.e. flat, dimpled etc? Also what would be a good brand to go with?
Thanks. As always any recommendations are welcomed.
Old Jan 8, 2004 | 02:18 AM
zjet's Avatar
i would use flat tops,get a replacement set for a lt1 from trw or speed pro your comb really desnt need high buck pistions.
Old Jan 8, 2004 | 06:11 PM
GrnHornet's Avatar
thanks J...man. I appreciate your help. I'm sure I'll have more questions later. Actually here's one now. What would be a good website to check as far as prices etc?
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
MadMav
Feb 6, 2015 11:02 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
