Stupid ABS prob still
Old Feb 20, 2004 | 09:47 AM
All4Chevy's Avatar
Ok, so back in the day i had the LOW TRAC light coming on...did a search and found that it was probably my rear abs sensor. I took it out and cleaned it, and right after i put it back in my abs light comes on after i drive about 15 feet. So beign that it happened right after that i am/was pretty sure it has to have something to do with my rear sensor. Because the light comes on after a few feet of driving and not right away, it seems it has to be the sensor (to me anyways) because it waits for the wheels to spin before sensing problems. Is it possible my rear sensor is completely bad and this can happen, or if it was bad would the light always be on? I just got it up on my brand new rino ramps (still had to use 2x8's to get up because of the body kit) and cleaned the sensor more thoroughly (um yea thats right) but the problem is unchanged. I just degreased my undercarriage and it is drying now, while it was up there i unplugged and blew in the front sensors, but i dont think that is gonna do any good. Any input on this?
Bill
Old Feb 20, 2004 | 02:15 PM
All4Chevy's Avatar
Do i just have bad luck with cars or somethign?
Bill
Old Feb 20, 2004 | 03:08 PM
americanmusscle's Avatar
Your sensor is prolly bad and it will need to be replaced. I had the same problem and I replaced the sensor and its all good now.
Old Feb 20, 2004 | 05:51 PM
slopokrodrigez's Avatar
Scan it and stop wasting time guessing. If you don't have a scanner, Autozone can scan your OBDII 96. Then take the result to a shop manual and figure it out from there.
Some times all is not what it appears to be. I kept getting a 57 or 56 saying one of the ABS wheel motors was bad. After testing according to the manual it turned out to be the BCM. Got one for $25.00 from a junkyard and saved $600.00. And all is well for the past year and a half.
good luck
Old Feb 20, 2004 | 10:57 PM
All4Chevy's Avatar
I would have gone to autozone, but they told me they only scan cars if the SES light is on. I figured they wouldnt do it for ABS then.
Bill
P.S. I plan on gettin it scanned by the dealership next week, i was just checkin ahead to see if i could save the $$
Old Feb 20, 2004 | 11:51 PM
JJ's95B4C's Avatar
Are all your taillights working? I had a similar problem, and I had the two upper lights(the ones on the spoiler) and one taillight out. Once I replaced the bulbs, the problem went away. Just a tip.
Old Feb 21, 2004 | 12:00 AM
All4Chevy's Avatar
Yes actually one of the lights was out, but i replaced both of them a few days ago and nothign changed, (i did that hoping it would fix my cruise control)
Bill
Old Feb 21, 2004 | 01:31 AM
Fatdog's Avatar
Cool
I read where some sensors at the wheels get corroded,not sure though,might check them.Myo2(might replace some fuses on the left side of the dash,even if they look good to you).Cheap stuff first.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
NewsBot
Sep 14, 2015 09:20 AM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
