stumbling when hot at idle, falls on its face?
Old Aug 25, 2005 | 09:49 PM
snakethis69's Avatar
just like it says above, when its around 160 it will start to idle around 500 or so, and when i hit the gas it kinda stumbles if i hit it moderatly hard then [ics up and pulls like a raped ape. i orignially thought this to be a sensor problem but have since decelared this out becuase i also have a hard start. if i prime the pump or let it sit till it stops priming my car will start fine on the first go around, somtimes. sometimes it will take 15 seconds of cranking i think this to be either a clogged fuel filter as it did this before the isntalls and it started right after i let the tank go pretty much dry twice. or i beleive this to be a failing pump. any suggestions and tips to point me in the direction would help.
Old Aug 28, 2005 | 08:28 AM
Re: stumbling when hot at idle, falls on its face?
no one has any ideas on this? it runs fine once above 1k or even at 800-900.
Victor Lamb
Aug 26, 2017 02:52 PM
meissen
Jun 1, 2015 07:59 AM
Nellsw88
May 27, 2015 10:27 PM
Dave19yz28
Jan 26, 2003 01:45 PM
Hoodshaker
Aug 27, 2002 02:32 PM
