Stumble, running rich and plugs
Old Jul 14, 2003 | 09:18 PM
JSK333's Avatar
I fixed several problems all by changing my plugs.
I used to have a low-end stumble and low BLMs. Well, I think the stumble was caused partly by me trying to tune the BLMs back to 128 (causing it to run lean some of the time, off-idle, etc.).
Anyway, I put in the new plugs, put my tune back to stock (injector constant from 33.5 to 31.7 for my 30# SVOs, stock MAFS tables), and my idle BLMs are RIGHT ON 128! :0
I can't hardly believe it! All this caused by plugs!
And the most amazing part... the plugs LOOKED fine when I took them out. No gunk, a lightish tan color, like everything was fine. But they were causing all the problems.
So, try replacing your plugs if you've had similar problems.
Old Jul 14, 2003 | 09:31 PM
96z's Avatar
96z
Interesting, were they copper or platinum and how many miles were on them?
Old Jul 14, 2003 | 09:49 PM
JSK333's Avatar
They were Autolite 104s (copper), with probably less than 5K miles on them!
I'm thinking they could have been "fouled" by my stock injectors going out awhile ago... but again, when I pulled them, they looked like every picture I've seen of a "good" plug.
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
IRABuss
Sep 7, 2011 09:08 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
