Stumble at idle when a/c is turned off?
Old Oct 6, 2004 | 11:20 AM
97Z-pimp's Avatar
Hey guys when i have my a/c running while im sitting at a light and then i turn my a/c off, the car stumbles pretty bad. It goes away though if i put the car into neutral and then back into drive. My volts also drop pretty low during this and while im making low speed turns in like a parking lot. Any suggestions....battery...alternator .....help
Old Oct 6, 2004 | 01:51 PM
n2ceptor's Avatar
Re: Stumble at idle when a/c is turned off?
Have the battery load tested, if the batt is good then check voltage at the battery with the car running, should be around 13.8~14.2... If not then its the alternator.. Or it could me the IAC.... Also, check for vacuum leaks...
Old Oct 6, 2004 | 03:45 PM
97Z-pimp's Avatar
AutoZone does this testing right?
Old Oct 7, 2004 | 12:16 PM
97Z-pimp's Avatar
ttt...I just got the battery and alternator tested and they both were good.
Old Oct 7, 2004 | 01:07 PM
Spllouder's Avatar
check ur compresser out maybe its going south ? and causing the problems
grgguy
17
Feb 23, 2015 07:57 PM
alphaauto
Feb 5, 2015 05:25 PM
CaRParts102
Dec 6, 2014 08:45 AM
Dave19yz28
Jan 26, 2003 01:45 PM
formula79
26
Aug 5, 2002 12:21 PM
