Stumble after EGR replacement
Old Aug 11, 2009 | 09:10 PM
Camm95Z28's Avatar
As noted in the title. I just had the EGR cleaned and I have a slight stumble low RPM 6 speed cruise.Is this pretaining to the EGR or is this a electrical issue? Thanks.
Old Aug 12, 2009 | 05:32 AM
Did you clean the gasket surfaces and insure the gasket was not damaged?
Old Aug 12, 2009 | 11:33 AM
Camm95Z28's Avatar
Actually found that the EGR wasn't cleaned, it was replaced totally.
The SES light does come onduring low RPM cruise when the stumble occurs.
Old Aug 12, 2009 | 11:40 AM
dangalla's Avatar
finding out the code could help, shbox.com should help you with that
he is asking if the gasket surface was cleaned on the intake manifold, if not it could be leaking exhaust gas into the system when not commanded to - even with a new gasket and egr valve
Old Aug 12, 2009 | 08:22 PM
Or leaking air......
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
jocamino
Dec 29, 2014 10:15 PM
thenewkid
Nov 18, 2014 12:57 PM
CobraEatr
Jul 29, 2002 11:46 AM
