stud girdle
Old Jul 23, 2008 | 10:57 PM
davisck2's Avatar
stud girdle
can any one tell me if any one makes a stud girdle set up for a 96 lt1?
Old Jul 24, 2008 | 07:57 AM
cnorton's Avatar
I used a Comp Cams small block girdle for two years on my race motor. I had no problems with the girdle itself other than the fact that it didn't stabilize the valve train adequately at 8200 RPM. Frequent valve adjustments were necessary until I switched everything to a T&D shaft rocker system.
Old Jul 24, 2008 | 10:47 PM
Ken95Z28's Avatar
The biggest issue would be to find one that does not interfere with the center bolt valve covers. Next would be to find a set of valve covers that would not hit the stud girdles. Moroso makes one that will do that or you can modify a set.
I bought a summit sbc girdle and did this.
Old Jul 16, 2015 | 11:22 PM
new2chevy's Avatar
Re: stud girdle
So the Summit stud girdle lined up properly with the studs on the factory GM heads?
Hopefully my tall valve covers would clear this girdle.
Old Jul 17, 2015 | 05:32 AM
bw_hunter's Avatar
Re: stud girdle
The rocker stud locations are the same on all small block Chev's since, at least, 1986. The only problem I had was interference with the center bolt valve cover bolts. I just notched them out and all was good.
If you install the tall rocker nuts on the rocker studs and don't have interference problems you're pretty good to go once you install the girdle.
Good luck!
Old Jul 17, 2015 | 12:07 PM
new2chevy's Avatar
Re: stud girdle
Thank you for your reply.
Much appreciated!
13qtr
Oct 28, 2016 08:11 PM
karpetcm
Sep 15, 2015 11:07 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
