Stuck! Rocker arms
Old Oct 17, 2011 | 09:45 AM
  #16
pgerst's Avatar
Re: Stuck! Rocker arms
"spinning the pushrod is almost guaranteed to make things too tight."
I have always used the spin method. I spin it back and forth in between my fingers and when I feel it start to resist, I tighten 1/2 turn more. Now I am worried it is too tight?
Old Oct 17, 2011 | 10:32 AM
  #17
You are fine.
Old Oct 17, 2011 | 11:50 AM
  #18
pgerst's Avatar
Gracias. Is there some method of using a dial indicator to determine this?
Old Oct 17, 2011 | 12:14 PM
  #19
Yes, you could use a dial indicator to detect up/down movement, but it would be way overkill, IMHO. The nice thing about hydraulic lifters is that they can handle a wide range of preload. Minor changes in preload can be made to suit your needs. As long as you are consistent from one to the next, you should be fine.
Wart Hog
Sep 8, 2015 05:53 AM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
94Form
Jul 17, 2015 10:56 PM
