Stuck! Rocker arms
Old Oct 10, 2011 | 02:00 PM
ShowOff67's Avatar
Stuck! Rocker arms
ok so i been reading how to set the zero lash. and then preload. but then do i have to torque the rocker arms? i have been spinning and spinning the rods and tighting down the bolt. i just dont understand this half turn 1/4 turn stuff if anyone could help it would be great! i was on shboxs site but i just dont understand the instructions anyone wanna put it in plain old english for me. i just dont wanna put this thing back together and have to take it apart to fix a knocking rocker arm. wanna get it right the 1st time. Thanks!
Old Oct 10, 2011 | 02:12 PM
ShowOff67's Avatar
Re: Stuck! Rocker arms
also how can i tell which intake and exhaust valve is which number. on shboxs it says at tdc cylinder 1
Intake: 1, 2, 5, 7
Exhaust: 1, 3, 4, 8
Old Oct 10, 2011 | 02:45 PM
jethrobodean's Avatar
When the exhaust lifter starts to go down, adjust the intake. when the intake bottoms and starts coming back up adjust the exhaust..... No matter what, you will have to readjust them while the motor is hot and running to get it right.....Been there done that..
Old Oct 10, 2011 | 03:04 PM
96capricemgr's Avatar
spinning the pushrod is almost guaranteed to make things too tight.
Zero lash is when the pushrod can't move up and down any more, then you go the fraction of an additional turn.
You didn't even tell us what rockers you are using, this is really easy with roller rockers as you can spin the polylock down with your fingers
Old Oct 10, 2011 | 03:18 PM
ShowOff67's Avatar
there stock rollers. and i will have to adjust when motor is running hot how so?
Old Oct 10, 2011 | 03:24 PM
bw_hunter's Avatar
No matter what? Ridiculous......if done correctly there is no need to do it hot with the engine running. The issue is simply finding zero lash and adding preload..people that have problems seem to have not found zero lash.
Old Oct 10, 2011 | 03:41 PM
bw_hunter's Avatar
Don't bother adjusting hot. Go to shbox.com and look up how to adjust the rockers....there are several different methods. Don't spin the push rod, move it up and down to find zero lash....
Old Oct 10, 2011 | 03:45 PM
ShowOff67's Avatar
ok so i went out there did 1st cylinder first did the up and down method was easy spun crank with a crowbar. better then hands i just hope i didnt make anything too tight if i did will it be hard to adjust with the intake back on ? 1st time doing this thanks for all the help guys. what i did was find zero lash then maybe about 1/2 to a full turn. its ok for the pushrod to be spinning still.
Old Oct 15, 2011 | 05:30 PM
camz28ryan's Avatar
no its not ok. your not doing it right. read shoe boxes site again until you completley understand.
Old Oct 15, 2011 | 05:46 PM
bw_hunter's Avatar
I disagree. The pushrod can spin with preload on the rocker....oil makes it possible.
Old Oct 15, 2011 | 10:03 PM
You are fine. It even warns the pushrod may spin once the lifter relaxes after adjustment. Read carefully and follow the directions.
From front to back(or back to front), valves are E-I-I-E-E-I-I-E.
Old Oct 16, 2011 | 08:02 AM
So you have an LT4?
Stock rockers are not roller on an LT1.
Old Oct 16, 2011 | 09:34 AM
Originally Posted by 96capricemgr
So you have an LT4?
If it happens to be a stock, factory LT4, they use shouldered studs that you merely tighten down and you don't have to worry about setting lash. The OP does not give much info as to what he is working on.
ShowOff67, the instructions on my site are already in "plain old english".
Old Oct 16, 2011 | 10:09 AM
My point was more that we can't help someone who doesn't even know what he has or what the parts are.
I will guess that when he said "stock roller" he meant the lifters.
Old Oct 16, 2011 | 10:57 AM
I kinda got that impression. I agree.
