Stubborn Issues
Old Mar 7, 2010 | 10:16 PM
Gerg007's Avatar
Unhappy Stubborn Issues
Okay, so pardon my longish list of stuff we've replaced, and the problems it caused/fixed:
-Ran fine, occasional missing, poor response, moderate power, engine light on-
Throttle Position Sensor
-slightly more responsive-
EVAP Purge Solenoid
Flushed Coolant
Replace Intake Manifold Gasket
New Smog Pump
-fixed engine light-
Spark Plugs (AC Delco Rapid Fire)
Fuel Filter
-started missing after warming up to the extent it was undriveable, idle rough, shakes on 400< rpm drops-
Distributor (MSD)
Plug Wires (Taylor, Spiro-Pro 8mm)
Water Pump (Reman'd)
Thermostat (Stant 180)
-Missed slightly less, surged at idle, poor power-
IAC Valve
-Fixed surging, moderate power, stopped missing until warmed up-
Fuel Injectors (24lb Aftermarket)
-better power, more responsive, only missed below 3000 rpm-
O2 Sensors
MAP Sensor
Ignition Coil (MSD Blaster Coil)
Fuel Pressure Regulator
-More power, better response, still idles rough, stumbles on acceleration below 3000 rpm-
It's currently idling rough, stutters and misses at 900-3000 rpm.
And any RPM drop of more than 400 causes the car to shake.
It idles around 6-800 rpm
Above 3000 the car accelerates fine, no major noises/issues.
Any suggestions would be greatly appreciated.
P.s. seems to be a clicking noise coming from the driver side of the engine, but too loud to tell.
Thanks,
Greg
Old Mar 7, 2010 | 10:40 PM
RamAir95TA's Avatar
Any current codes or SES lights?
Do you have the option of scanning in real-time? This can tell you all kinds of good stuff.
Old Mar 7, 2010 | 10:44 PM
scr0tum's Avatar
Could the clicking noise be the tick of an exhaust leak? I only say something because I had an exhaust leak for a long time on my 93. It ran fine after i got the leak fixed and the o2s changed. Having power above 3k can be due to the tune. I believe that in the 93s the fuel map takes over at a certain RPM/Throttle level. Just a shot in the dark from personal experience.
Old Mar 7, 2010 | 11:21 PM
Have you checked for:
-faulty IAT sensor
-leaking EGR valve
-heat soak on IC module
Old Mar 8, 2010 | 01:01 AM
maddog05's Avatar
Check for air leak with a vacuum guage or your ears
When an engine after all you have done runs well above 3 M and stumbles below it can mean:
    air leak somewhere on the intake side of the engine
    a vacuum hose somewhere is leaking or disconnected
    Old Mar 8, 2010 | 02:33 AM
    Gerg007's Avatar
    None whatsoever >.<
    Possible. Have smoke coming out from behind the engine, most of which is caused by an oil leak (where ever THAT is coming from.) I plan on replacing the entire exhaust as soon as I know I won't need to pool cash in elsewhere.
    -faulty IAT sensor
    -leaking EGR valve
    Havn't checked the EGR yet...didn't even think of the other two
      We checked them all thoroughly when the car was still surging, before the IAC valve
      (It was idling at 1000 rpm, and occasionally jumped up to like 2700 >.<)
      Thanks guys, after seeing some posts and talking to people around the area I'm changing the Delco's and throwing in autolites. I've read to use a .050 gap, but autolites say use a .060 and the factory plugs we took out were gapped at exactly .060. It ran better prior to changing them. Not sure if it'll help or not but..
      Old Mar 8, 2010 | 05:08 AM
      Guest47904's Avatar
      Guest
      Ton of parts but little troubleshooting going on
      My first issue is the intake manifold and the fact that you still have an oil leak at the back of the engine. If you were there doing the manifold why wouldn't you at least identify where the oil leak was coming from?
      Next issue is when you did the plugs. you said this:
      Fuel Filter
      At that point you back up and at a minimum reverse the step you did to what appears to create the problem.
      Now I'm really confused by the next part:
      Fuel Filter
      Distributor (MSD)
      IAC Valve
      Isn't "started missing after warm up" the same thing as "stopped missing until warmed up"? And if you gained a miss until warm and then lost it, we don't know.
      You did the plugs and fuel filter and gained a miss after warm up. Then you did a ton of crap and still had the miss after warm up. Yes or No?
      The most common "off idle" miss is the EGR. Seems most likely the problem. BUT you don't have to replace it to figure out if it's the problem.
      Last point or question really is when did the "tick" show up? Was it after the plugs were put in? This is a very common place for a tick. Many MANY folks screwed up the plug install and now one or more is leaking at the head and the "sudden gush" of gases past the plug sounds like a tick.
      I think you know how to check for leaking plugs.
      Old Mar 8, 2010 | 05:54 PM
      Gerg007's Avatar
      Fixed! Idle is still a little off, but nothing I can't figure out over time. Autolite 606's gapped at .060 and it's golden -.- 2 plugs were fouled out, but so far the new ones are good.
      Oh and Speedy, tickings gone, #3 plug was a little loose.
      Thanks all =)
      rocknroler69
      Apr 29, 2015 10:24 PM
      sseeya
      Apr 9, 2015 06:38 AM
      Alex Barnes
      Jan 24, 2015 10:21 PM
      rpm4lalo
      Jun 7, 2002 02:10 PM
      95_RipperZ
      11
      Nov 11, 2001 09:48 AM
