Strut tower install question
Old Jun 22, 2003 | 12:03 PM
sorryofficer's Avatar
Okay, I feel like an idiot, cause this should be a 5 minute install. But i can't get my new strut tower brace on. I undid all the bolts, and jacked up the passenger side. Then i put the brace on the drivers side, and tried to get it on the bolts on the passenger side and its too short. I even stood on my rim to pull the studs down into the strut tower more, almost to the point where they were even with the metal surface, and it still won't fit. Am i missing something with this?
Old Jun 22, 2003 | 12:08 PM
95TA8280's Avatar
What brand STB is this? I didn't have to jack up my car to get my BMR one in
Old Jun 22, 2003 | 12:41 PM
NiteRider's Avatar
Yeah what brand is it? Is it a 3 point STB, perhaps the back part is hitting the cowel and not allowing you to put it in? Give us some more info bud. You sure as hell don't need to jack anything up for a STB install.
Old Jun 22, 2003 | 01:13 PM
Hyperspeed97z28's Avatar
my SLP unit went it, 5 mins... what did you guys use to tighten that one bolt on the pass side??? the one near the A/C line??
Old Jun 22, 2003 | 02:51 PM
BPS's Avatar
BPS
Re: Strut tower install question
Originally posted by sorryofficer
jacked up the passenger side. I even stood on my rim to pull the studs down into the strut tower more, almost to the point where they were even with the metal surface, and it still won't fit. Am i missing something with this?
What are you doing??? - undo 4 bolts, put on STB, refasten 4 bolts - 5 minutes tops. NO jacking, standing, pulling studs or any of that stuff!
Old Jun 22, 2003 | 02:55 PM
95TA8280's Avatar
Re: Re: Strut tower install question
I don't know about 5 minutes....the passenger side was a b!tch because of all the hoses and clearence issues with the ratchet/wrench....took me about 20 minutes but it certainly wasn't hard....
Old Jun 22, 2003 | 10:20 PM
kostya_f's Avatar
I had a similar problem, but i know my car has been seriously wrecked on one side. It did fit after the same trick you were using.
Old Jun 23, 2003 | 12:45 AM
When you buy a bar with relatively small holes for the bolts/studs to pass through, it is not unusual to require the studs on one side to be retracted. The studs are angled out at the top - they are not true vertical, meaning that the bar appears to be too short to fit over them. I guess if you bought a bar with big, sloppy oversize holes, it wouldn't be a problem, but with the 4-pt LG Motorsports STB, it was necessary to retract the studs on one side before the bar would fit over them.
Why it still won't fit with the studs retracted is a bit unusual though.
Old Jun 23, 2003 | 12:51 PM
k, i bought the car when it was three years old, but it has never hit anything that would cause any damage (unfortunately i can't claim it never hit anything but it wasn't hard at all). Well, i'm calling the manufacturer today, this is killing the confidence, if i can't install a strut tower brace, should i bother trying to do headers?
Thanks for the help so far guys
Old Jun 23, 2003 | 04:25 PM
revtime's Avatar
Just cause your having trouble with the STB does not mean you should question your ability to work on the car.
I think you are being too gentle with it.
I beat the pi** out of mine to get it on.
It wanted to fight but I was determined to win.
Old Aug 1, 2003 | 11:00 PM
CamaroGuy22's Avatar
I dont think my BMR came with bolts...what should i do?
Old Aug 2, 2003 | 10:44 AM
revtime's Avatar
You reuse the bolts that are already on there, unbolt them slip on STB and then put bolts back on and tighten.
Old Aug 15, 2003 | 01:34 PM
Alright i got the STB on, and the bolts all tight, cept the bolt on the passenger side that is being blocked by the AC crap....i tightened that one up as tight as i coudl get with my fingers, is that ok or does it need to be tighter? All the other bolts are very tight, this one i cant get to with a wrench...what should i do? leave it alone or what?
Old Aug 15, 2003 | 03:02 PM
Get a box wrench and go in from the back. Not easy, but doable. Maybe a "stubby". Force the wrench as hard as you can by hand. Might also consider a "crows foot wrench" to get in there. I wouldn't leave it "finger tight". Believe me, if the shock tower only needed three bolts, GM would have deleted one of them.
Old Aug 15, 2003 | 06:28 PM
Bud M's Avatar
Try putting on the passenger side first, without the car being jacked up.
