stronger stock lt1 replacement rod bolts & main bolts?
Old Aug 8, 2009 | 10:49 AM
c5formula's Avatar
i know that the ls1 guys can pull their oil pans off an swap rod bolts when they want that extra safty factor but do they make rod bolts for the lt1 that can be swaped in in the same way? can some one give me a part number on them? im about to pull my oil pan an put on a new oil pump an would love to throw some stronger rod bolts in there fro the added strength.
also does arp or some one make any stronger than stock replacement main bolts that could be swaped in there with the motor still in the car while the oil pan is off?
Old Aug 8, 2009 | 11:16 AM
Kevin Blown 95 TA's Avatar
You can buy ARP fasteners or some equivalent stronger bolts & studs for the mains and rods, but it would be pretty hard to swap rod bolts with the crank in there and if the new bolts distort the rod ends then your bearing clearances might be affected. Milodon also makes studs and there's a few others..
Old Aug 8, 2009 | 02:20 PM
Z-RATED94's Avatar
It's not something you do with motor still together. Their pressed in from the factory I believe. If you do figure something out you can come do my motor.
Old Aug 9, 2009 | 02:28 AM
c5formula's Avatar
wonder why its so easy for the ls1 boys to swap rod bolts with the motor still in the car just by removing the oil pan...
Catmaigne
Dec 25, 2014 12:16 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
GigaMp3z
Feb 20, 2003 02:57 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
mjcent922
Jul 27, 2002 12:42 PM
