Thoughts on bigger stall (3800-4000) with smallish gear (3.73's)
Old Sep 11, 2006 | 09:31 PM
Javier97Z28's Avatar
Moderator
Anyone have a 3800-4000 stall car with a smallish gear in the back like a 3.73?
What kind of 60's are you cutting and how rough is the car to drive on the street. Looking at picking up a tranny off a member here and I'll need to get my converter freshened up so I might as well get it restalled while it's there for my LE3 powerband.
I have a 3200 stall with 3.73's right now, and it's fine.
I probably won't be picking up a 12 bolt until sometime later next year, and that will have 4.11's or 4.30's in it, so it'll be a temporary thing.
Old Sep 11, 2006 | 10:48 PM
chy20k1's Avatar
Re: Thoughts on bigger stall (3800-4000) with smallish gear (3.73's)
ive been in a car with 3.73s and i think a yank 4k. it ran/drove great. i'd ask around the ls1 section, alot of those guys run bigger verters all the time.
Old Sep 11, 2006 | 11:10 PM
Hark_z's Avatar
Thought it really depended on your cam range as well. I'm looking into a 3600-4200.
Old Sep 12, 2006 | 12:30 AM
Jameslt1TA's Avatar
You might as well go with the bigger stall, espesially if your planning on the 4.10 twelve bolt within a year or so. I like my 3600 but it a 3800-4 would probably work better and im pretty sure your cam is bigger than mine.
Old Sep 12, 2006 | 05:01 AM
cehan's Avatar
Javier, most of the TC companies have a Tech Line that can probably give you some good advice on what to use, based on your setup and intended application.
Old Sep 12, 2006 | 08:23 AM
SStrokerAce's Avatar
Javier, your new cam likes converter. A 4000 stall will work really well with it and better than the 3200.
Bret
Old Sep 12, 2006 | 08:47 AM
Honda Hunter's Avatar
I'm going with a Yank4000 with 3.54's. LS1tech has some really great info and threads about it.
Old Sep 12, 2006 | 09:08 AM
Moderator
Allright.. that brings up my next question.. how efficient is a Vigilante at that high a stall speed compared to a Yank.
Can of worms opened!
Old Sep 12, 2006 | 10:32 AM
OneFlyn95z28's Avatar
mine seems to be working good Might even need a little more stall
Old Sep 12, 2006 | 12:36 PM
n20fed's Avatar
My vigilanate stalls to right at 4100 on the brake(4000 stall). I figured my effeciency to be 92.5% at 6500 rpms with 3.73 gears. Now, with the nitrous I was seeing about 22% slippage at the same rpm.
Old Aug 9, 2009 | 05:57 AM
Bersaglieri's Avatar
I wouldnt mind hearing feedback on this. Plus hearing what n20fed said about 22% on juice makes you wonder. What is that 4000 flashing at with the juice?
Javier I know you like your Yank better...
-Dustin-
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
