stroker question
I know this question is very basic and i did try the search feature but i am still confused in a couple areas on this subject. I know that by using a 400ci crank in combination with 5.7 or 6 inch rods that a 350ci engine is transformed into a 383ci engine. I have also heard alot about a 406ci engine, i assume that it is derived from a 400ci block. Is this motor stroked? Im under the impression that it uses a stock 400 crank along with 5.7 or 6 inch rods. Is it just bored over 6 inches? What does the extra 6 cubic inches do to add the extra power these motors make? How about the 496ci engine that i sometimes hear about? Is that a stroked 454? I also remember hearing about the 302ci in the late 60's early 70's Z-28. I think i was told that they actually used a 327 block with a smaller crankshaft to squeeze or destroke the motor. Does this allow the motor to run a higher compression ratio? It would be great if someone could set me straight on this because whenever i get the money i want to build one of these engines and it would be great if when i told somebody about it i knew what i was talking about.
Your question is all over the place! But in a nutshell:
350 block bored .030" plus 400 crank (3.75" stroke)=383
400 block bored .030" plus 400 crank (3.75" stroke)=406
The 302 was a 327 destroked to allow the motor to compete in competition with Ford 302s. A destroked motor doesn't allow for more compression, but a destroked motor is generally oversquare, and lends itself to higher revs due to decreased piston speed versus longer stroke motors.
squirrels
Jul 13, 2002 01:58 AM
