stroker question
Old Jul 28, 2003 | 01:26 PM
Rob94's Avatar
Question stroker question
I know this question is very basic and i did try the search feature but i am still confused in a couple areas on this subject. I know that by using a 400ci crank in combination with 5.7 or 6 inch rods that a 350ci engine is transformed into a 383ci engine. I have also heard alot about a 406ci engine, i assume that it is derived from a 400ci block. Is this motor stroked? Im under the impression that it uses a stock 400 crank along with 5.7 or 6 inch rods. Is it just bored over 6 inches? What does the extra 6 cubic inches do to add the extra power these motors make? How about the 496ci engine that i sometimes hear about? Is that a stroked 454? I also remember hearing about the 302ci in the late 60's early 70's Z-28. I think i was told that they actually used a 327 block with a smaller crankshaft to squeeze or destroke the motor. Does this allow the motor to run a higher compression ratio? It would be great if someone could set me straight on this because whenever i get the money i want to build one of these engines and it would be great if when i told somebody about it i knew what i was talking about.
Old Jul 28, 2003 | 06:52 PM
Rob94's Avatar
TTT
Old Jul 28, 2003 | 07:49 PM
Josh-'04 GTO's Avatar
Your question is all over the place! But in a nutshell:
350 block bored .030" plus 400 crank (3.75" stroke)=383
400 block bored .030" plus 400 crank (3.75" stroke)=406
The 302 was a 327 destroked to allow the motor to compete in competition with Ford 302s. A destroked motor doesn't allow for more compression, but a destroked motor is generally oversquare, and lends itself to higher revs due to decreased piston speed versus longer stroke motors.
Old Jul 28, 2003 | 08:05 PM
IrocManiac's Avatar
Good post...on a side note didn't the Chevy 302 have the 4 in. bore spacing like the 350? So it could also be called a destroked 350? The way I was told was a 327 was a destroked 350 and a 302 was a destroked 327 or 350...just obviously less stroke...shorter stroke or an overly square bore allows the motor to rev higher while piston velocities remain at tolerable levels.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Newgmman
Feb 25, 2015 02:53 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
squirrels
Jul 13, 2002 01:58 AM
