Stroker Oil Pump
Old Jul 19, 2005 | 12:29 AM
  #46
SStrokerAce's Avatar
Re: Stroker Oil Pump
Arnie...
Just threw the pump on a oil pump "dyno" that I made today.... A GM White Spring will do 80PSI if there is enough restriction for it, saw it with my own two eyes today the pressure relief valve does open at 80PSI, maybe I can get OldSStroker to help out and I can get a pic of the thing at 80PSI for ya.
The anti chatter grooves are basically there to keep the vibrations down to keep ignition timing accurate, a longer gear like a HV gear helps the same way. The HV also has the volume advantage also for larger bearing clearances.
BTW with the stock spring I never said you didn't have to shim the spring some to get the right pressures did I? Either shims or a adjustable spring stop.
Bret
Old Jul 19, 2005 | 04:31 PM
  #47
arnie's Avatar
No need, I believe you. Apparently, the restriction on my end, was not great enuf to generate that PSI. BTW, that was with extra shimming besides. Although, I have a tendancy to get over aggressive with the pressure bleed grooving on the ends of the gears, which may affect pressure. I know it affects idle pressure.
My error for not explaining myself better. Not disputing the anti chatter grooves, just the similar merit from the HV pump.
Old Jul 19, 2005 | 07:22 PM
  #48
Arnie to add to this I talked to a buddy of mine today who does circle track motors (one of his guys is on a 4 race win streak right now, and no it's not Tony Stewart) he uses a M55HV pump on his 355 motors with around .0030 clearance and the low pressure spring and he sees 60-65psi max in the motors. Volume is another way to get pressure, personally I like tighter clearances and a set pressure relief on a standard volume pump to get what I want.
Bret
Old Jul 19, 2005 | 08:28 PM
  #49
1racerdude's Avatar
Bret
I used to use the BB pump in all my roundy round engines. They now have these HV pumps so I use them.I use a HV on all my high HP builds 'cause most are set up with .0025 or better clearance's I also use the 3/4" pickup and a Canton road race pan on most(swinging trap doors) that's maybe why they don't blow up when the put um on the bumper, which several have.
Old Jul 19, 2005 | 11:00 PM
  #50
Yeah if I open the clearances up I go with a HV pump but on .0020-.0025 NA setups (most times at .0021-.0023) I just stick with a stock GM pump. I also go with the trap door pans, windage trays, scrappers etc... really take care of the oil system and I don't run excessive oil in the pans either, easy way to eat up 5-10hp with too much oil in the pan of a stroker.
Bret
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
