Stroker Oil Pump
Old Jul 14, 2005 | 07:08 PM
  #16
arnie's Avatar
Re: Stroker Oil Pump
Originally Posted by swemdog
what is the difference in springs on the stock system vs. the "white" spring?
Obviously, the 'white' spring is stiffer, to delay bypass opening.
I hope it was not meant to be a trick question.
Old Jul 14, 2005 | 09:06 PM
  #17
rskrause's Avatar
Moderator
I have said this about 1K tinmes before, but just to perfectly clear: DO NOT use a HV pump with a stock pan.
Rich
Old Jul 14, 2005 | 09:20 PM
  #18
arnie's Avatar
Agreed Rich. I'll go one step further, and state, for 99.4% of street drivn engines, there is no reason to justify a HV pump. Another one of those 'race only' mods that some how made it's way to the 'street'.
Old Jul 14, 2005 | 09:23 PM
  #19
rskrause's Avatar
Moderator
Yep, I agree with your agreement
A motor with loose clearances might not be able to maintain optimum oil pressure with a stock volume pump, that would be the reason for using a bigger pump. There is no other reason. And if you use a bigger pump you need a pan with more capacity.
Rich
Old Jul 15, 2005 | 04:22 PM
  #20
swemdog's Avatar
I guess I asked the wrong question; will that spring work with a stock system? Can I just swap the springs?
Old Jul 15, 2005 | 04:25 PM
  #21
93ZM6Tally's Avatar
Yes you can. I know a couple of guys locally doing that very thing.
Old Jul 15, 2005 | 04:37 PM
  #22
swemdog's Avatar
alright, i know i have a lot of questions, but I didn't even think about my oil pump when I began piecing my stroker together. I'm glad I came across this thread and about the oil cooler in a search (I think I'm ditching that). I don't mean to hijack your thread but I gotta ask another...
Should I get a different pump, or reuse my stocker? I spun a rod and a main bearing. There were metal shavings everywhere in my engine. Should I just clean it out and reuse it?
Old Jul 15, 2005 | 05:14 PM
  #23
93ZM6Tally's Avatar
Please, don't even consider using an old pump during an engine rebuild. Hell a replacement Melling pump would run you a whopping $25.00, add another $15.00 for a pickup. Saving $40.00 by re-using your stocker just doesn't make any sense. I'd probably recommend an ARP Steel Pump shaft too. The plastic POS shafts are an accident waiting to happen.
Old Jul 15, 2005 | 05:24 PM
  #24
FastZinTennessee's Avatar
I plan on using an oil cooler when I get the motor back together. The guy at the machine shop said that using a H.V. oil pump with the cooler would be a good idea. Opinions?
Old Jul 15, 2005 | 06:10 PM
  #25
swemdog's Avatar
hey guys, thanks for the info and replies.
Old Jul 15, 2005 | 06:15 PM
  #26
1racerdude's Avatar
Loose the cooler and keep the pump.
Old Jul 15, 2005 | 06:36 PM
  #27
swemdog's Avatar
what about this?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
its got the 3/4" inlet, a screen, and a steel driveshaft. Not a bad price?
Old Jul 15, 2005 | 06:49 PM
  #28
1racerdude's Avatar
what about this?
Don't know who Elgin is or about the quality. Don't risk your new engine.Get a name brand pump Melling,Moroso,Seal power,etc.
The pickup ya have is it used? If so it won't fit right unless ya get or make a bracket to hold it on.
Old Jul 15, 2005 | 07:06 PM
  #29
mastrdrver's Avatar
To make this clear, HV/HP pumps are for when you change bearing clearences. You change the calculated "oil leak" from the bearings, so you must provide more volume/pressure to correct the extra leak. From what you have said, you are not changing bearing clearences or turning insane rpms, therefor a HV/HP oil pump is a waste of money. Some will ask what is the hurt in running more oil, my answer is what ever the price difference is between the stock pressure and the HV/HP unit. If you have ~10psi for every 1000rpms, you will be fine.
Old Jul 16, 2005 | 03:13 AM
  #30
rskrause's Avatar
Moderator
It can hurt (a lot) if you suck the pan dry. Which can, and does happen if you use a HV pump with the small stock oil pan and run an extended time at high rpm.
Rich
