Stroker kits
Old Oct 24, 2009 | 01:07 PM
nubucks's Avatar
Stroker kits
Ok so in my previous post i basically askd everyones inputs and opinions on 355 vs 383 and i decided to just go all out with a 383 stroker. Can you guys recommend me GOOD quality forged stroker kits.
Old Oct 24, 2009 | 01:23 PM
Power adder or normally aspirated? HP target? RPM limit? Budget?
Old Oct 24, 2009 | 02:15 PM
1-fuel's Avatar
go 396 it cost allmost the same....eagle 4340 is a good starting point..crank $650 rods i think $450 and srp pistions are $500
Old Oct 24, 2009 | 02:43 PM
96capricemgr's Avatar
Compstar speedpack.
Old Oct 25, 2009 | 01:26 AM
nubucks's Avatar
well i want a n/a 383 stroker and i want to build a forged bottom end with the best parts. strong to where i can feel comfortable about jumping on the gas and not worrying about the motor. can people give me recommendations and give me links. ive heard alot of good stuff about compstar packs
Old Oct 25, 2009 | 02:41 AM
Prorac1's Avatar
You need to think about what your doing with this motor. To many times people build a "fully forged" bottom end so when they "jump on it" they wont break anything. IMHO if your just planing on building a heads and cam enhanced 383 making 400-450 rwhp, you can save a lot of money and use a cast crank, eagle sir rods and a forged piston. Put the extra money into heads and valvetrain. To often people build killer bottom ends only to run out of money and use some limp heads on it and only dyno 350 rwhp.....................but it has a fully forged bottom end. Before any build you have to think what YOUR going to use the car for. You can ask for a hundred opinions but thats just what your going to get. A hundred people telling you what YOU want. So in other words, unless your going with nitrous, forced induction, etc, I see no need in building a $2,000 bottom end. Just my .02 Eric L
Old Oct 25, 2009 | 07:30 AM
and too many times guys have used cast Eagle cranks and had them break taking out a whole lot of other parts.
Old Oct 25, 2009 | 09:40 AM
Prorac1's Avatar
Thats why I mentioned Eagle SIR rods, but not their crank, lol. Im not a big fan of their cranks either. But I dont think they will break when you slam the throttle. Eric L
Old Oct 25, 2009 | 11:01 AM
If you are set on forged components, check out the Compstar line, produced by Callies. They are "imported" parts, but subjected to Callies rigid quality requirements. If you don't want imported, move up from the Compstar to the Dragonslayer.
http://www.compstarcomponents.com/index.htm
http://www.callies.com/
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Drtryder
Apr 22, 2015 04:17 PM
Sauced
Apr 12, 2015 10:18 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
