stroker guys?how relilble
Old Jul 31, 2004 | 07:32 PM
rob97ss's Avatar
Whats up guys I'm just about done with my 383,just want to see how relilble your motors have been for you,how long have you had it ?how many miles have you put on it trouble free?
Old Aug 1, 2004 | 05:42 PM
rob97ss's Avatar
Re: stroker guys?how relilble
where are all you 383 guys
Old Aug 1, 2004 | 11:51 PM
Leedogg 96TA's Avatar
I have over 10,000 hard mile on mine so far....not a problem yet. (well I blew up my opti ) But so far so good...I don't see any reason why a stroked motor should live a much shorter life.
Old Aug 2, 2004 | 08:53 AM
93ZM6Tally's Avatar
Nothing inherently un-reliable about a stroker motor. Like any other motor the reliability comes from it being correctly assembled, probably most importantly is the machine work and bearing clearances, next in importance would probably be piston to cylinder wall clearance and ensuring that the bored/honed surface is appropriate for your ring selection. Beyond that would be cooling considerations, ensuring that your existing radiator is up to par or better yet adding an aftermarket radiator. Newly rebuilt engines tend to burn hotter and a 383 will normally run slightly hot because of decreased cylinder wall clearance. There is of course a lot more things to consider such as tuning and AF ratios, but these factors are considerations for any motor, even a stock rebuild.
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
spearous
Jan 12, 2015 11:03 AM
Red97LT1
Aug 7, 2002 05:45 PM
squirrels
Jul 13, 2002 01:58 AM
