Stripped Oil Drain Plug???
Old Feb 18, 2004 | 09:12 PM
joecool72's Avatar
Question Stripped Oil Drain Plug???
Ok, did an oil change this past weekend and I think I over-torqued the drain plug because once it got to a certain point it started to just spin. It's on tight but I'm concerned if I stripped the plug or the thread on the pan. What do you guys think???
Old Feb 18, 2004 | 09:20 PM
Tall Guy's Avatar
You probably just stripped the drain plug. It seems to be made of softer metal than the pan threads. It shouldn't be a big deal to remove provided there is still enough thred on the plug to spin it out. If it's completly striped out you'll probably have to use vice-grips and plull on the plug to 'help' the threads grab. Be sure to clean the threads on the pan before you put in a new plug. Hope this helps...
Old Feb 18, 2004 | 10:16 PM
bdc95ta's Avatar
I did the same thing about 3,000 miles ago. When I tightened it up back then I remember it spinning just a little and thinking darn I screwed up some more threads. when will I learn...anyways I striped the pan threads not the bolt so I went to autozone and they gave me a new bolt that would tap new threads so I used that and screwed it up even more. b/c the cars low to the grown, and it's at a diff. angle and you have to put a wrench on it to get it rethreading right but when I would turn it it would throw it off a little. B/c it wasn't a balenced force been applied to it. If that makes any sense whatsoever; the direction your turning the wrench is which way the bolt wants to reangle. if i had to do it all over again I would of just used a standard tap and die set i think it would of been easier b/c you woundn't have that problem. So now that I messed it up bigger than the biggest tap I have I went ahead and got a used pan off of ebay. hope this helps
Old Feb 18, 2004 | 10:34 PM
S.J.S.'s Avatar
Hey Joe, first off you need a sig man so we know what kind of car you got. Anyway, if nothing else works I got a pan here. Let me know.
Magenta_Hearts
Mar 29, 2017 08:54 PM
eanhl2004
Apr 4, 2015 12:01 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
