stripped header bolts
Old May 28, 2005 | 10:43 PM
NewbieWar's Avatar
well like the title suggests while putting on my headers i stripped some header bolts, so how might i fix the situation so i can tighten them down to stop exhaust leak?
Old May 28, 2005 | 10:56 PM
1racerdude's Avatar
Re: stripped header bolts
Drill,tap,heli-coil.
Old May 28, 2005 | 10:58 PM
NewbieWar's Avatar
... drill into my baby... im no dentist or doctor, i'll leave it to a mechanic (w/ warrenty)
Old May 28, 2005 | 11:06 PM
1racerdude's Avatar
They will probably pull the head to do it,where you could figure a way to do it without going through that.(angle drill,short bit)
Old May 28, 2005 | 11:18 PM
Heatmaker's Avatar
Advanced Member
You stipped the bolts or the Heads? Try removing the bolt with a 12point if you haven't done so yet...
Old May 28, 2005 | 11:20 PM
NewbieWar's Avatar
12 point?
I stripped the aluminum heads... on probably 4 bolts...
Old May 29, 2005 | 12:59 AM
Heatmaker's Avatar
Advanced Member
Oh.... your post was confusing said you stripped the Header bolts...
If you stripped the heads themselves out than I don't see what the big deal is. I ended up stripping 2 holes myself on an install. All you have to do is remove the header.... and buy yourself a 3/16 tap, and hand tool. You just simply place the tap in the hole and re make the threads. THe tool is small enough to fit on either side of the engine bay, so there should be no need to take the head off. It's not that serious...all it takes is patience to fix. The only time when you may need to pull a head off a car is if you actually broke a bolt off in the header hole... now that ... that's a real issue.
good luck.
Homedepot sales the tap tool.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
