Stripped EGR nuts, need opinions
Old Apr 20, 2005 | 02:23 PM
lookingforwheels's Avatar
Angry Stripped EGR nuts, need opinions
Hey guys I'm in the process of installing headers and I just stripped the 2 EGR nuts that hold the pipe on that goes to the mainfold. I let them soak in WD-40 overnight but the still stripped right off, I tried using a stripped nut removal kit but it's too tight back there to work. My question is if I just put a big vacumn cap on the end of that metal pipe will I be okay? I have a block of plate for the manifold side and I have had the EGR disabled in a tune from MADz28.
What do you guys think?
Thanks for the input.
Old Apr 20, 2005 | 03:12 PM
Re: Stripped EGR nuts, need opinions
If you have a plate to replace where the EGR valve goes, the pipe side does not even matter (except for keeping the manifold passage clean).
Old Apr 20, 2005 | 03:41 PM
So if the pipe is exiting the back of the intake manifold I can just let it hang there? I was thinking about putting a 5/8 vacummn cap on it(I have one left over from blocking the air passage on my CAI) I have the block off valve plate for the exhaust manifold, so the exhaust wont be leaking.
(EDIT)
http://shbox.com/ci/AIR.jpg
I used your site a little, basically the number 14 bolts are stick onto the number 13 studs, and where the number 12 plate would hook up to the manifold I have a block off plate so there won't be an exhaust leak, so in the diagram if you look at the large number A with the arrow, on my car that pipe is just sitting there open on that side.
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
pepon214tx
Sep 20, 2015 04:48 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
