Stripped EGR nuts, need opinions
Hey guys I'm in the process of installing headers and I just stripped the 2 EGR nuts that hold the pipe on that goes to the mainfold. I let them soak in WD-40 overnight but the still stripped right off, I tried using a stripped nut removal kit but it's too tight back there to work. My question is if I just put a big vacumn cap on the end of that metal pipe will I be okay? I have a block of plate for the manifold side and I have had the EGR disabled in a tune from MADz28.
What do you guys think?
Thanks for the input.
Re: Stripped EGR nuts, need opinions
So if the pipe is exiting the back of the intake manifold I can just let it hang there? I was thinking about putting a 5/8 vacummn cap on it(I have one left over from blocking the air passage on my CAI) I have the block off valve plate for the exhaust manifold, so the exhaust wont be leaking.
(EDIT)
http://shbox.com/ci/AIR.jpg
I used your site a little, basically the number 14 bolts are stick onto the number 13 studs, and where the number 12 plate would hook up to the manifold I have a block off plate so there won't be an exhaust leak, so in the diagram if you look at the large number A with the arrow, on my car that pipe is just sitting there open on that side.
(EDIT)
tdigger9899
Sep 7, 2015 10:56 AM
