Strange starting problem
Old Apr 22, 2004 | 02:50 PM
valter's Avatar
Question Strange starting problem
I have very annoying problem with my car. Sometimes when I try to start it I just turn key and starter are not even trying to crank engine. All lights on dash behaves normal, it's look like PCM can't detect whether clutch pedal is depressed or smth. The major pain that it happens sometimes and there no one right way to make it start - so troubleshooting is pretty hard. Most of times car starts after turning key off for 10-20 seconds, playing with clutch, etc. Battery is fine. I'll appreciate any ideas.
Old Apr 22, 2004 | 03:00 PM
CamaroUK's Avatar
Perhaps the VATS Pass key thing can't read your key resistance value correctly?
Old Apr 22, 2004 | 03:18 PM
valter's Avatar
I think that is quite possible. I'll check it. If I can remember all these times clear, problem always appeared after key removal. Thank you!
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
StngStlkr
Sep 6, 2002 05:47 PM
