Strange problem, need help
Old Nov 10, 2005 | 11:35 PM
GnarlyZ28's Avatar
I went to start my car, but when i turned the key only te accessories came on, but the engine wouldn't even try to turnover. I notice a "security" light in the cluster. The car finally started when the key was jiggled around in the ingnition. The security light stayed on for a little while, but then the ses light came on and has stayed on ever since.
I have no idea what this could mean, any advice would be appreciated.
Old Nov 11, 2005 | 02:58 AM
Randy L's Avatar
Re: Strange problem, need help
My '97 did the same thing once, when I rolled it down the driveway to wash it. I didn't start but the accessories came on as well as the security light. After resetting the security system she started right up.
Old Nov 11, 2005 | 04:38 AM
Guest47904's Avatar
Guest
The pellet in the key wears down as well as the contacts in the ignition switch. You can either replace the key or the ignition switch as necessary or simply bypass the function all together.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
1996LT1Z28
Apr 22, 2015 07:56 PM
ShwaZedder
Apr 9, 2015 06:33 AM
