Strange Electrical Problem
Old Feb 23, 2004 | 08:14 AM
jasonpadams's Avatar
I have a 95 Z28 & when I turn the lights on, the Low beams barely "bleed" over into the high beams and fog lights. The low beams are at full power & the others should be out but are barely shining. My low coolant warning light illuminates on my dash, and the right turn signal indicator on the dash just barely illuminates. It gets even stranger when I switch the fog lights on, the right front headlamps go out and the turn signals quit working. As long as I don't turn the lights on at all, everything seems to work correctly. I assume I have a short or more likely a bad switch. I have disconnected the battery to reset everything & the problem comes back. I'm hoping these cars have a history of maybe a certain switch going bad in them. Otherwise I could be looking at a lot time troubleshooting this problem. Any thoughts or suggestions?
liamcg97
Nov 25, 2019 05:55 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
eanhl2004
Apr 4, 2015 12:01 PM
97z28k&N
Jan 9, 2015 04:58 AM
