Stock Wire w/LTs
Old Oct 20, 2004 | 10:04 AM
BigBlue95Z's Avatar
Stock Wire w/LTs
Can you still run the stock wires w/Jet-Hot LTs?? I've got a pretty good exhaust leak at the manifold and have the LTs to put on but not the new wires yet. Probly won't for a month or 2.
Old Oct 20, 2004 | 11:04 AM
jbsupra89t's Avatar
Re: Stock Wire w/LTs
i'll be running stock ROUTED msd 8.5s, i did a bit of searching on the same subject and discovered more than a couple guys doing the same, some even with stock GM wires.
-J
Old Oct 20, 2004 | 11:11 AM
madwolf's Avatar
I run stock wires with LTs. No problems at all. (dyno graph is very smooth)
Don't plan to change them either...they work just fine.
Old Oct 20, 2004 | 11:12 AM
FastZinTennessee's Avatar
If you have the money, scrape up the $100 or so that it takes to buy the over the valve cover wire kit. It is 10 times easier than trying to route the wires in the stupid stock location, plus it looks really nice in my opinion. Basically, $100 now saves you a lot of frustration in the future with routing and burning out wires(if it happens).
Old Oct 20, 2004 | 11:35 AM
atljar's Avatar
I ran wires in the stock location for over 2 years and only burned 1. That was at first start after the headers, and one was touching. Whoops. Just be more careful than i was.
Old Oct 20, 2004 | 01:25 PM
krispy's Avatar
no burnt wires with pacesetter LTs, not sure how different in design they are though
Old Oct 20, 2004 | 02:46 PM
DrivinSidewayz's Avatar
i run msd 8.5 in the stock location with FLPs, youll be fine, no wire is even close the to the headers
Old Oct 20, 2004 | 09:24 PM
revtime's Avatar
I run MSD 8.5s with my Hookers and with my custom routing job have never burned a wire. Its all in the routing, take your time make sure its right and you won,t have any problems, even with stock wires.
canbaufo
May 25, 2015 12:01 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Rich_z28
Aug 27, 2002 12:20 AM
Evilfrog
Aug 7, 2002 11:36 PM
