Stock Valve Covers
Old Sep 24, 2003 | 10:28 AM
MRCAIN's Avatar
Stock Valve Covers
I'm getting ready to put things back together on my 95 z28
A4, after putting in a new piston pin and getting a valve job
ect... However, I came accross some roller rockers from summit
racing, and would like to know if I can use my stock covers with them? The number on the rockers is SUM-G6910-1 any help would be nice, as well as photos of aftermarket covers if I can't get away with stock.
Old Sep 24, 2003 | 10:34 AM
Josh-'04 GTO's Avatar
Are those rockers self-aligning? If not, you can't use them with the stock valvetrain. If you still want to run them, you'll need pushrod guideplates and hardened pushrods.
Old Sep 24, 2003 | 12:59 PM
The stock covers will generally fit aftermarket roller rockers. I checked that part # on the Summit website, and it has no information other than a part #, the fact that they are 1.5X and 3/8", and "not available". As pointed out in the post above, you need to see if they are compatible with the LT1 valve train. You need self-aligning, and you might want to consider going to 1.6X to get a little extra lift out of the cam.
I run Comp Cams Pro-Magnum 1.6 roller rockers (with guideplates and hardened pushrods) and they fit inside the stock covers with some minor trimming of the center-bolt support gussets. Aftermarket valve covers for the LT1/F-Body are fairly rare, since the F-Body setup requires a "dimple" on the front of the passenger side cover to clear the alternator.
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
