stock timing chain install
Old Mar 5, 2007 | 10:28 PM
AlmostfastLT1's Avatar
Hey I am installing a new stock timing chain on a 96LT1 anyone have some good directions, I am more used to the sbc stuff and was wondering some good pointers with all the waterpump gear stuff,etc.
Thanks Mark
Old Mar 5, 2007 | 10:35 PM
Also how do you know how far to go when installing the new crank sprocket on the snout of the crank
Old Mar 6, 2007 | 12:26 AM
blackztpi's Avatar
its pracitcally the same as gen 1 small blocks. it just has another gear for the water pump. installation is the same. keep cranking the sprocket on until it stops moving or has a sharp metallic sound when hitting it. that means its up against the crank all the way
Old Mar 6, 2007 | 06:42 AM
2000GTP's Avatar
Shoebox has the directions in his cam install tutorial that also has some pics as well. http://shbox.com/ci/cam_install.html
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
