Stock springs handle 1.6 rr's?
Originally posted by SSnakeEater
dont you have to take the heads out to get the springs out? doesnt this make things pretty complicated?
Just use an overhead valve spring compressor. Either use compressed air or the TDC method to hold the valve up, compress the spring, remove the keepers, and remove the spring.
Originally posted by RamAir95TA
Nope. Heads can stay bolted to the motor.
Originally posted by lbrowne
How does the compressed air work? I would have done it the TDC method, which is easier/faster?
overhead valve spring compressor can fit way in the back of the engine compartment?
Easily. It's not very big. I used a generic one from Advance Auto, found on the shelf, and it actually worked better than the popular KD compressor.
oldschool
Feb 9, 2016 09:21 PM
