stock rebuild high oil pressure
Thought the high pressure was due to being a rebuild but after about 400 miles its still high. cold idle is 60psi, warm idle is 40psi, cruising its at 60psi and at WOT it only goes up to about 64psi. Changed the pressure sensor and it's still the same. will it go down after some more miles? The pump is just a stock replacement.
Posted from Camaroz28.com App for Android
Re: stock rebuild high oil pressure
Looks good to me. Try putting an aftermarket gauge on there to see for sure however, I would not worry at all standard volume and high pressure is good. It may have the white GM spring inside which is for high pressure
Sent from my LG-P999 using Tapatalk 2
Why do you think that is bad? If your bearing clearances were on the tight side, your hot idle pressure might trend to be a little higher than most. Also, you don't indicate the oil you are using.
I don't know what's bad and what isn't. I'm no expert. I just worry.... So I turn to this site for assurance. It's 5w30. Just changed it today after 400 miles on build.
Just didn't know if high pressure was a sign of something not right inside.
Ok lol thank you! I appreciate you and everyone else on this forum that knows a lot about these cars.honestly without this website and shbox.com,I would be lost.
Fred brings up a good point. Alot of reported failures with the fram filter and I am sure they may make some of the other generics. I also would imagine some may perform better with your higher idle pressures. Might be well worth checking with a mechanical guage to confirm your readings. Certain oils have different flow characteristics given their weight especially synthetics. Might notice small differences there.
Personally I would run wix or the napa brand that wix makes for a filter that most parts stores will stock. Another member uses (I believe moroso) and I read up on their filter and was interesting. I was looking into all this with my low oil pressure. I have had mechanics say for years not to run fram. I have read of several others saying the same and have heard of some of the failures. Definately worth the few extra dollars in my opinion.
Problem is, the test results change from year to year. The Fram filters got their reputation based on a physical examination of the filters, done at least 15 years ago. A recent study had bad results for the AC Delco filters. Hard to keep up with the tech.
Here's an interesting site, that appears to use valid scientific methods. I am not endorsing this site, just bringing it to your attention. I found it interesting.
Oil Filter Comparison Study - GM Truck Central
Untitled Document
Note that the "weighting" of factors used to develop the numerical "grade" may not match your priorities.
Untitled Document
Brandon Wittmer
Dec 20, 2014 09:51 PM
Jul 4, 2005 05:00 PM
