Stock PCM RPM limit
Old Jul 28, 2004 | 09:50 PM
LT1 S-10's Avatar
Stock PCM RPM limit
Is it true that the stock PCM cannot support over 7200rpm?
Old Jul 28, 2004 | 11:22 PM
Re: Stock PCM RPM limit
Factory programming tables end at 7000 rpm.
Old Jul 29, 2004 | 12:52 AM
atljar's Avatar
The obd1 computers actually shut down at 7k. Once you hit 7k, the ECM shuts down, your motor stops running completely. You have to key off, and restart the car.
OBD2 stuff doesnt shut down at 7k, but there are no tables beyond 7k rpms. Therefore the car runs like crap past that. I have heard that the ecm uses the 7k cells for every rpm past 7k, (ie same fuel, timing etc) but i have no evidence to support that either way.
Old Jul 29, 2004 | 08:31 AM
LT1 S-10's Avatar
We are running OBD2 and have spun the motor to 7300RPM, but our MPH on the big end seemed low. Does the GEN6 sound like the way to go?
Old Feb 12, 2007 | 12:46 AM
TurboSS's Avatar
atljar
your wrong the computer and car does not shut off.
Limit is 7200ISH then the PCM thinks it is spinning around 3650.
TAD
Old Feb 12, 2007 | 01:22 AM
sbs's Avatar
sbs
Originally Posted by TurboSS
atljar
TAD
Well, I guess bringing back a 3 year old thread makes that two year old thread you brought back look slightly less stupid...
Old Feb 12, 2007 | 11:19 AM
TurboSS's Avatar
Wow you must be bored...
Again ppl building solid roller motors will need to know solid info on this if they are looking this up
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
canbaufo
May 25, 2015 12:01 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
97SSdude
Dec 31, 2014 07:43 PM
