stock lt1 maf w/ 58mm tb
Old Dec 20, 2006 | 08:54 PM
itzkwik's Avatar
will the stock mass air meter hurt the air flow of the larger throttle body
Old Dec 20, 2006 | 09:00 PM
rasputin's Avatar
nope
Old Dec 20, 2006 | 09:40 PM
DrewHMS97SS's Avatar
Youll likely see wot bog with a 58mm tb and a stock lt1.
Old Dec 20, 2006 | 11:37 PM
itzkwik's Avatar
not stock ,355,11.6.1cr,cc306,comp1.6rr, ported heads 273in.,181ex.@.500lift @ 28in/hg. Had ported maf on it with 48mm tb ,dry nos 150hp worked fine,switched to 58tb hit the button and got extremely lean condition,pop popop pp op aww crap we blew up something, i thought , didnt hurt motor but broke some mounts or someting , gunna put the completely stock maf on it and se what changes I get and put the nos noSZle system on,I know there is a lot of people running high hp w/ dry set up but I have had more people tell me to go with the wet and I got it to put on ,Plus its gunna look coool
Old Dec 21, 2006 | 08:21 AM
2000GTP's Avatar
What kind of injectors are you running? A hungry heads/cam motor and a pretty decent sized dry shot is going to require an upgrade. If your injectors aren't big enough, that will easily lead to a lean condition.
Old Dec 21, 2006 | 12:59 PM
trax's Avatar
LG Motorsports made nearly 500 rwhp on a stock-bottomend LS1 using a stock, screened, unmolested 75mm MAF.
Old Dec 21, 2006 | 08:12 PM
Who cares about the bottom end? The bottom end is nothing more than an air pump. The biggest concern is breaking when you mention a stock bottom. If you put a 58mm TB on a stock top end, you are likely to see bog.
Old Dec 22, 2006 | 05:37 AM
96capricemgr's Avatar
And now you know why you should not go hacking up MAFs, the stocker is THE right choice, aftermarket are downright BAD. The ZO6 MAF can be made to function and is a little freer flowing BUT with our pcm it maxxes out about 360gps so tuning beyond that is a little more work to ramp up fuel based on rpm rather than gps. Seeing as my little heads/cam motor moves more than 360gps you should be prepared for your motor too as well.
Old Dec 22, 2006 | 08:16 AM
RE AND CHERYL's Avatar
You don't need a 58mm TB. A 52mm TB will do just fine even with the juice.
Re'
Old Dec 22, 2006 | 11:01 AM
I don't think he was making a point about the stock bottom end.... he was pointing out "using a stock, screened, unmolested 75mm MAF."
Old Dec 22, 2006 | 05:58 PM
Did I read that wrong? Initially it looked like a slam about what I had said. Re-reading probably not. My mistake.
Old Dec 22, 2006 | 07:05 PM
itzkwik's Avatar
Re'
I was told differently from golen engines and loyd elliott,
Old Dec 22, 2006 | 07:06 PM
itzkwik's Avatar
svo 30#
DirtyDaveW
Dec 1, 2016 05:37 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Killer94z
Jan 13, 2015 12:06 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
