stock LT1 HP\TQ?
Old Mar 21, 2005 | 01:14 PM
britts85's Avatar
stock LT1 HP\TQ?
What does a stock LT1 put down?
Old Mar 21, 2005 | 02:12 PM
Rampage139139's Avatar
Re: stock LT1 HP\TQ?
It is normally said to be 300hp and 350tq but I have heard it stated at 280hp and 320hp. Always 350tq though.
Old Mar 21, 2005 | 02:23 PM
britts85's Avatar
Is that to the ground? And how much does 4400ft of elevation hurt that number?
Old Mar 21, 2005 | 02:41 PM
stereomandan's Avatar
Rampage, where did you get those numbers from?
Actually, flywheel HP for '96-'97 LT1's is 285 hp and torque is 325 ft-lbs, before that they were rated at 275 hp, but all years around the same power.
Actual rear wheel numbers depend on if you have a 6 speed tranny or 4 speed auto.
6 speed:
255 rwhp/290 rwtq
auto:
245 rwhp/280 rwtq.
There are online calculators to determine what altitude does to the power numbers.
Dan
Old Mar 21, 2005 | 03:36 PM
britts85's Avatar
Ok that makes me feel better. I dyno'd my 383 and with 15:1 A\F and it poping and back firing during the pull I still put down more then a stock LT1. I've got an auto. and I had to replace the PCM cause my last one got water in it and shorted out. So I had to get another PCM and haven't tuned it yet. I'll get that done and strap her down again. I was talkin to some of the guys at the place i dyno and they were sayin that 15:1 is murder to my motor(no **** is what i was thinking) and the amount of power i was losing due to it, is huge.
Old Mar 21, 2005 | 05:11 PM
Yeah, power loss, and your motor is running friggin HOT at 15:1. It's normal for a car to run around 14.7:1 at idle and cruising, but not at Wide Open Throttle. You should get it down to 13.0:1
Dan
Old Mar 21, 2005 | 05:50 PM
britts85's Avatar
Any Idea what the power loss is with a 15:1 A\F at WOT?
oldschool
Feb 9, 2016 09:21 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Jason Short
Jan 19, 2015 06:34 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
