Stock injectors with cam
Old Feb 18, 2012 | 02:00 PM
greenformula94's Avatar
Can stock injectors be used with a cc502 cam?
Just wondering as I just ordered the cam and Ill order injectors in I need them, was gonna go with a 30 or 32 bosch injector
Old Feb 18, 2012 | 03:31 PM
raroz28's Avatar
Re: Stock injectors with cam
Do a google search on calculating fuel injector horsepower. There is an equation you can do.
I think you would be ok running stock injectors up to like 300 HP, but I have seen people who have dyno'd 400 HP and run on stock injectors with just an upgraded pump and regulator.
How much power do you think you will make with that cam?
Old Feb 18, 2012 | 04:17 PM
You can run about 360HP at the flywheel on stock injectors, limiting the duty cycle to 85%. You should be OK with just a cam.
Old Feb 18, 2012 | 06:40 PM
I have a walbro type fuel pump, no aftermarket fuel pressure regulator.....
Old Feb 18, 2012 | 08:03 PM
Stock fuel pressure regulator is good for big HP. Don't worry about it.
canbaufo
May 25, 2015 12:01 PM
spearous
Jan 12, 2015 11:03 AM
birdblack
Dec 30, 2014 06:59 PM
chuyz28
Nov 25, 2014 11:14 PM
