Stock Injectors
Old Sep 10, 2005 | 06:04 AM
Honda Hunter's Avatar
Stock Injectors
How much horsepower can the stock injectors support?
Old Sep 10, 2005 | 08:20 AM
Re: Stock Injectors
They will be below 90% duty cycle up to about 375 flywheel HP. That's at stock fuel pressure (43.5psi). With a higher fuel pressure, they could support more.
Old Sep 10, 2005 | 08:29 AM
Re: Stock Injectors
For my mods which injector size do you recomend?
Old Sep 10, 2005 | 12:31 PM
truedualws6's Avatar
Re: Stock Injectors
You should consider upgrading to larger injectors with your setup. I'm just
about at the limit for the stock injectors and you will definately be making
a lot more HP than I do.
Old Sep 10, 2005 | 12:33 PM
Re: Stock Injectors
Do you already have the LT4 28# injectors? They will be below 90% DC up to about 420 flywheel HP. You need to tell us what your flywheel HP is to pick an injector. Can we assume your NX kit is a wet kit?
Old Sep 10, 2005 | 12:37 PM
Re: Stock Injectors
I'm leaning toward some ford 30 pounders. Do you think that would be enough if persay I'm making 400fwhp?
Old Sep 10, 2005 | 12:39 PM
Re: Stock Injectors
I have the stock lt4 injectors. Hopefully my computer from PCMforless should be in next week, then Ill get it on the dyno to see where I'm at.
Old Sep 10, 2005 | 01:58 PM
Re: Stock Injectors
You also need to respond to Freds question too on the NX kit. You dyno
session should tell you a lot so be sure to include A/F in your pulls.
Old Sep 10, 2005 | 02:03 PM
Re: Stock Injectors
Yes it's a wet kit. Are the LT4 injectors bigger than the LT1's? If so then I really need this tune because I'm using a stock tune from a 94 LT1.
Old Sep 11, 2005 | 07:13 PM
Re: Stock Injectors
LT1 (94-97) are 24#, the LT4's are 28#, as posted above. You could live with them at 400 flywheel HP. A set of 32#'s would give you room for future increases.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
spearous
Jan 12, 2015 11:03 AM
