Stock GM coil vs Accel coil
Old 10-10-2003, 11:05 PM
luis nunez's Avatar
Guys I am thinking about replacing my coil, I had the stock one but, I think it went bad, so I replced it with an accel that I had used, I wan to know wich one will work better,electricaly,
GM stock or the accel on a LT1
luis nunez is offline
Old 10-10-2003, 11:23 PM
ny_z28man's Avatar
should work about the same. The coil will put out only what it needs to. If your running lean it'll produce more voltage, if your running rich it'll produce less. Accel may reach full saturation faster, but I dont see any major performance advantages.
ny_z28man is offline
10-31-2016 11:09 AM
canbaufo
05-25-2015 12:01 PM
DirtyDaveW
03-15-2015 07:01 PM
MyShibbyZ28
02-14-2015 12:05 PM
Catmaigne
12-25-2014 12:16 PM
Quick Reply: Stock GM coil vs Accel coil
