Stock Fuel pump ok with 30lb injectors??
Re: Stock Fuel pump ok with 30lb injectors??
Originally Posted by elguapo
yes. But when it geos out one day, upgrade. Nice to have one that's capable of a lot more. I probably would upgrade if you have the money though.
You probably could have just used your stock 24lbs injectors.
None the less, once in awhile, it would be a good thing to actually throw a guage on the setup and watch your fuel psi WOT while under a load.
Lloyd recomended the 30 pounders. How much HP can the stock injectors support. I should be around 380 or maybe a bit more at the wheels. They are LE1 heads with larger valves installed.
