Stock Fuel pump ok with 30lb injectors??
Old Mar 14, 2005 | 12:22 PM
jchevy's Avatar
Recently did LE1 heads/cam package. Is my stock fuel pump good enough to feed those injectors?
Old Mar 14, 2005 | 01:24 PM
1-bad-z28's Avatar
Re: Stock Fuel pump ok with 30lb injectors??
Originally Posted by elguapo
yes. But when it geos out one day, upgrade. Nice to have one that's capable of a lot more. I probably would upgrade if you have the money though.
just what i was thinking.
Old Mar 14, 2005 | 02:29 PM
CANTONRACER's Avatar
You probably could have just used your stock 24lbs injectors.
None the less, once in awhile, it would be a good thing to actually throw a guage on the setup and watch your fuel psi WOT while under a load.
Old Mar 14, 2005 | 03:17 PM
jchevy's Avatar
Lloyd recomended the 30 pounders. How much HP can the stock injectors support. I should be around 380 or maybe a bit more at the wheels. They are LE1 heads with larger valves installed.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
HectorM52
Jul 30, 2017 11:46 AM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
